E-brake snapped...help
if i remember right you pull the center console out and use a punch to move the ebrake cable out of the ebrake assembly and pull it out through the bottom of the car then you unhook the front cable from the two rear and squeeze the metal bracket and pull the line out from under the car and reverse to install it
