408 pistons?
4.000" Crank, 4.030" Bore, pretty much the same as what I have in the LS style, just the LT1 Rods are 6.000" instead of 6.125".
I wonder how they do.
This is where I got my info..
This is a 408 LT1 shortblock. With good heads that go 320+ CFM like TFS and AFR LTx heads 525+ at the wheels has been made.
Core Block LT1
Eagle 4340 SBC 4.000 Crank #435340006000 for
LT1 one piece RMS
Callies Compstar 6.000 SBC Rods W/ ARP 2000 rod
bolts W 2.000 Big Ends
Wiseco Custom Pistons (No Power Adders any
compression)
Wiseco GFX Piston Rings
ACL MS909 H Main Bearings for 350 SBC
ACL CB 663 H Rod Bearings for 2.100 SBC
Chamfered Race Bearings
Durabond CH 8 SBC Cam Bearings uncoated
Eagle 400 SBC Splayed Caps 18 degree
ARP 4-Bolt Main Studs without windage tray for SBC
Freeze plugs kit and Misc
pm for pricing, this is an informational thread
Core Block LT1
LT1 one piece RMS
compression)
how much were your pistons and i kinda thought i was going to have a custom set just trying to see what brands everyone thinks are the best.
A 408 is not that bad you can get the crank off ebay and pick a set of rod and find a good shop to clearence it.
Moderator
Mahle does not offer a off the shelf piston for any LT1 with a 4" stroke (unless something has changed recently). The only option I had when building my 410 was to buy a custom piston. I paid $675-700 for the Diamond's if I remember correctly.
Jason
There are mahle pistons that are stocked at mahle for a 4.0 stroke sbc with a 6.0 inch rod. They are offered in .030, .040, and .060. I purchased a set from Competition Products. They are offered only in the Power Pak series which comes with a rings set. These pistons have the 1 inch CH. for those interested in it I will find my reciept to get you the part number.
FWIW: I chose the eagle 4.0 forged crank, and the Scat Pro Comp I beam rod which has additional clearancing done for strokers, with these mahle pistons. The rotating assembly just clears everything, using these rods, with about the same clearancing as for a 3.85 stroke crank. Also with these pistons and rod combination the balancing works very nice as the lightweight of the rod and piston combo allows for a very noticable amount of material to be removed from the crank. I had my assem. balanced by shaving the crank throws and combined with the Prof Prod LT damper and Fidanza Flywheel the machine shop expects a fairly fast revving engine. I just got in my heads and I will be starting a thread soon, posting some pics of all the parts I have chose to use.
