No Defroster after A/C Firewall Delete
Old 08-17-2009, 09:42 PM
Marc3.4V6's Avatar
Default No Defroster after A/C Firewall Delete
I deleted the A/C box from the firewall while doing head gaskets and put a plate over the hole, kept the vac line going to the dash for the check valve, but when I go to use the defroster/fan it will just make a weird spinning noise from behind the glove box....what gives? I was told and read several times that my defroster would still work. I need it in the winter, it's dangerous without it.
Old 08-18-2009, 05:57 PM
enjoi355's Avatar
idk about the problem your having... but i was wondering how do you even take that thing out??
Old 08-18-2009, 07:17 PM
Low N Slow's Avatar
I have seen pics on here, you need to make a sheet metal piece and mount it in the heater box behind your block off plate to direct the air coming from the fan.
Old 08-18-2009, 10:16 PM
Marc3.4V6's Avatar
hmm, I'd think I would have seen that, I'll have to look at the pics sprawled out around the different threads on it. Thanks for that....there's hope afterall.
Old 08-18-2009, 11:09 PM
Marc3.4V6's Avatar
is this what you mean?
https://ls1tech.com/forums/8481461-post29.html
Old 08-19-2009, 08:22 AM
the_merv's Avatar
Yea, you need to cut that center section out and put something there so the Blower Motor can send air through the Heater Core.
Quick Reply: No Defroster after A/C Firewall Delete
