93 LT1 Idles @ 1800
93 LT1 Idles @ 1800
I've got a 93 Lt1 in my '77 Volvo 244. It has been idling at 1800 rpm and I can't figure out why. I have tried reseting the IAC, checked for vacuum leaks, and made sure the TPS is reading right. Does anyone have an idea of what to check next?
Vacuum leak? (specifically, the brake booster or one of the larger lines on the TB unplugged?)
Are there any other things to look for?
It sounds like you put a bigger throttle body on recently. Mine did the same thing until I twisted the IAC toward the front of the motor so far the the top screw actually sits behind the IAC. This set the idle down to about 850-900rpm.
It's actually all stock execept for the exhaust.
Could you explain this a little more? I've never had the IAC out and don't really follow.
http://www.ls1lt1.com/forum/showthre...ight=high+idle
try that... it may answer a question.
I have found that ls1lt1.com is the BEST lt1 advice you can get.
LS1Tech Sponsor
Last LT1 I bought for a retrofit did the same thing. After two weeks of looking for vacuum leaks and wiring problems, I realized someone had put the throttle body on (before I purchased the engine) without a throttle body gasket. You may want to double check.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
