witch oil pan is best for drag racing lt1
Old 12-06-2009, 05:56 PM
383racecar's Avatar
Default witch oil pan is best for drag racing lt1
been running my stocker going high 9.s, looking to upgarde witch is the best i see a few options out there between moroso and canton,
Old 12-06-2009, 06:01 PM
BIG PURPLE's Avatar
i ran a moroso 7qt. i never had any problems.
Old 12-06-2009, 07:08 PM
383racecar's Avatar
i didnt see a 7qt, i was looking at http://www.moroso.com/catalog/catego...?catcode=17001
Old 12-06-2009, 07:20 PM
RamAir95TA's Avatar
I am running the 242T by Canton.
Old 12-06-2009, 07:24 PM
kierstyn's Avatar
I am running a sbc moroso 7qt its a nice piece just does away with the low oil sensor because its for a sbc.
Old 12-06-2009, 07:48 PM
383racecar's Avatar
that would work great i dont run a oil level sensor anyway, no clearence problems? do you happen to know the part #?
Old 12-06-2009, 08:42 PM
fergymoto's Avatar
I used to run the Moroso pan also, the LT1 F body specific pan. It was pretty trick with a windage screen, crank scraper, and trap doors all built in.
Old 12-07-2009, 06:05 PM
kierstyn's Avatar
Cant remember the part number for sure but its just a regualar old sbc pan with the dipstick on passenger side and I have a tubular Kmember so no fitment issues on mine. I am pretty sure it would work with the stock kmember also.
Old 12-07-2009, 06:27 PM
Greaseymec's Avatar
Running a Kevco 7 qt pan. No fitment issues on a stock crossmember.
Mec
Old 12-07-2009, 06:30 PM
bigj2717's Avatar
i have a 7 qt milodon sbc and it clears the stock k-member just doesnt have the low oil sensor
Old 12-07-2009, 07:28 PM
LS1 SPEED's Avatar
Hamburger pan here with a UMI K-member
no oil level
Old 12-08-2009, 12:51 PM
383racecar's Avatar
ok thanks guys.
Old 09-14-2010, 09:08 PM
Wicked94Z's Avatar
canton with the half *** windage screen removed... i have a moroso tray in there now and it solved my oil pressure issues.
Old 09-14-2010, 09:41 PM
WS Sick's Avatar
I'm using the 7 quart moroso with kicked out sump it is pretty well level with the bottom of the K-member. For windage I used a welded in the pan fitted crank scraper and a Moroso windage tray clearanced for the dipstick and extra drainage holes added. I run a quart low and have no oil pressure issues.
Old 09-14-2010, 10:55 PM
slomarao's Avatar
Im going with a 5qt canton. Since your a 383 go with the 7qt.
Old 09-15-2010, 07:34 AM
quik95lt1's Avatar
got the canton......with 6 quarts of 20/50 it sucks the pan almost dry and i had a fluctuation in pressure on braking after the 1/4 mile......i run 7 quarts in it and the problem is gone
Old 09-15-2010, 05:10 PM
Wicked94Z's Avatar
20/50 huh? What kind of bearing clearances are you running in that thing? Thought of putting an accusump on there?
Old 09-16-2010, 07:20 AM
quik95lt1's Avatar
yea its loose...... .003 on the rods and .0028 on the mains......accusump wouldn't be a bad idea your the second one to say that
Old 10-14-2010, 12:21 PM
Rob94hawk's Avatar
Got a part# for this? (searching) How many quarts does it run? I'm gonna be using the Melling 10% HV pump so I'm looking for something that holds an extra quart.
Ah, found it: http://www.moroso.com/catalog/catego...?catcode=17001
A little cheaper than the Canton I was gonna get: http://www.summitracing.com/parts/MO...94&prefilter=1
What oil pump are you running with this pan^^
Also, everyone that is running without a low oil level sensor, what do you do with the wire and do you have to change the pcm code for this?
Old 10-14-2010, 12:28 PM
1badzee's Avatar
Remove the bulb in the gauge cluster.
Quick Reply: witch oil pan is best for drag racing lt1
