head gaskets for boosted LT1
Old 05-26-2010, 02:35 PM
TAHOE5.3's Avatar
Default head gaskets for boosted LT1
What headgaskets are being used for a high boost LT1?
Old 05-26-2010, 03:11 PM
boosted LT1's Avatar
Not sure what you refer to as high boost but somewhere near 15 psi coppers take the lead. I have my block o ringed with copper and supposedly it will take ~30 psi.
I prefer copper head gaskets, ansd used them even on 12 psi. I have never had a problem with copper and on my rearmount I have run 21 psi without o ringing.
But as it is always said, boost pressure only shows the restriction to boost, rwhp is a better measure. Either way I recommend copper head gasket on three of mine and a few of friends (all >18 psi) LT1's zero failures.
Good luck
Old 05-26-2010, 03:30 PM
TAHOE5.3's Avatar
you answered just about everythng I needed to know. I'll probably be right in the neighborhood of 25psi.
thanks
Old 05-26-2010, 03:42 PM
Tony Shepherd's Avatar
I have two brand new sets of copper head gaskets still in the package. They have the special coolant passage seals built into them. .040 thick.
$140 plus shipping per set.
Old 05-27-2010, 08:00 AM
TAHOE5.3's Avatar
I'll keep those gaskets in mind I'm dropping the motor back off to the builder so he can pick some new dish pistons.
Old 05-27-2010, 11:26 PM
Z28&WS6's Avatar
o-rings and copper gaskets here too. was running mls but got a good deal on a set of heads and they were already o-ringed. you may waant to consider the o rings with 25lbs but the mls may be ok too.
Quick Reply: head gaskets for boosted LT1
