Carbed Lt1 Ideas
i made a whole carb swap parts list thread..
650-a 750 carb is all you need..a 650 with a small cam and stock or even ported stock heads will get you buy for the street..im only using a 750cfm carb and ill be around 700hp on juice..thats stock heads,stock long block,an comp cams nitrous 276 cam
thats nice to think..lol it can be done though seen it before with 165-180cc heads
cam is not 276@50 either..man that would be a fucked up over cammed combo..
11.4-1 comp
c16
holley 300-25 intake
750dp
1.7 rr's
224/236 @ .50
.568/.589 lift
113 lobe
headers pretty much open only using a small 6" schoefield muff per side
no accessories but alt.
valve cover evac system.
b&b oil pan with built in scraper an windage tray.
11.4-1 comp
c16
750dp
1.7 rr's
224/236 @ .50
.568/.589 lift
113 lobe
11.4-1 comp
c16
750dp
1.7 rr's
224/236 @ .50
.568/.589 lift
113 lobe
11.4-1 comp
c16
750dp
1.7 rr's
224/236 @ .50
.568/.589 lift
113 lobe
