drill the thermostat ?
Old 07-28-2010, 10:37 AM
killagt's Avatar
Default drill the thermostat ?
Today I replace the new thermostat, with stant super stat, I took my old one off and I saw it have 2 hole ( look like some one drill it ). After I put new stat in, I saw it running hotter then the old one that have drill hole on it.
Idle Old 200 after 15min or 20 min
Idle New 215 after 15min or 20 min
Cruising Old 170-180
Cruising New 190-193
it its different, should I drill the new one with hole ? any one done drill mod on thermostat ? btw I change out the old thermostat cause the seal is leak around the thermostat housing.
Old 07-28-2010, 10:52 AM
Village Troll
SS RRR's Avatar
LS1Tech 20 Year Member
You most likely have a traditional SBC t-stat. You need one specific for reverse cooling.
Old 07-28-2010, 10:59 AM
killagt's Avatar
This is the one I bought.
Old 07-28-2010, 11:11 AM
Nastyc4's Avatar
you most likely had a 160 stat in there before
Old 07-28-2010, 11:41 AM
killagt's Avatar
so as long my tempeture never pass 210, im good right ?
Old 07-28-2010, 11:45 AM
shbox's Avatar
LS1Tech 10 Year
Considering the fans are not programmed to even come on until 226°, you are fine. Don't drill any holes. And yes, it does sound like you might have had a 160° thermostat in there before. The thermostat has a marking on it somwhere, telling you the temp rating.
Old 07-28-2010, 11:50 AM
1993 z28 f1's Avatar
Hey:
Good till 230+ or so with that Tstat. I would go with a 160*
Tstat and get a tune for the fans to come on at 195* because of where you live.
Dub
Old 07-28-2010, 12:00 PM
killagt's Avatar
Originally Posted by 1993 z28 f1
Hey:
Dub
I got hypertech tune the fan on at 160, but I dont like how my fan keep kick on all the time, I already just sold the hypertech yesterday.
btw if i make my engiine run cooler, will it increase engine life ? I mean if I leave the way its now, will it be ok for engine life ? hehe I want this engine last a long as possible.
Old 07-28-2010, 12:08 PM
Hey:
killagt:
Most Likely it will last longer @ a lower temp. Hence the reason for the choice of a 160* in warmer climates.
Dub
Old 07-28-2010, 12:16 PM
killagt's Avatar
where can i buy 160* localy ? if not localy where can I buy at online for best price ? thanks
Old 07-28-2010, 12:21 PM
Hey:
Autozone, NAPA, Advanced or OReilys take your pick, give em a try just make sure it looks exactly like the one you have.
Dub
Old 07-28-2010, 12:35 PM
killagt's Avatar
Thanks I got one order at autozone, in 4 hours I should have it, any one have any ideal how long the thermostat last ?
Old 07-28-2010, 01:10 PM
J-13gtp's Avatar
Ive been running mine for over two years now. Its a wise investment.
Old 07-28-2010, 01:44 PM
killagt's Avatar
any one know who made duralast thermostat ? I also heard motorad made it. is this true ?
I heard motorad made the hypertech thermostat ? is this true ?
Old 07-28-2010, 01:51 PM
97lt1camaro's Avatar
I have a motorad 160 in my Camaro from crappy tire. Cost me $22.
Old 07-28-2010, 02:35 PM
Hey:
Just a guess, but a T stat should be good from 1-5 yrs easy as long as you keep fresh clean coolant in it, maybe longer. I never changed the one in my Caprice ever, never needed to and it has been 200,000+ miles and 16 years old.
Dub
Old 07-28-2010, 03:13 PM
killagt's Avatar
I went to autozone and open few duralast theromostat and all em have motorad name on it. how come 160* cost way more then 180* ?
Old 07-28-2010, 04:16 PM
Hey:
killagt: I went to autozone and open few duralast theromostat and all em have motorad name on it. how come 160* cost way more then 180* ?
Just the way it is, the law of supply and demand, 160* popular, 180* not so much.
Dub
Old 07-28-2010, 05:00 PM
projectX's Avatar
Do you NEED to change a thermostat from stock one if you just hypertech program the fan to come on at 160/180 ?
Old 07-28-2010, 08:12 PM
Hey:
The fans will be running all the time, and will not last as long that way. Why not just put in a cooler stat, and turn the fans up to turn on, when you really need them while stopped. While in motion with the air damn in place it cools it pretty good without them running.
Dub
Quick Reply: drill the thermostat ?
