Auto Tranny Rev Limiter?
Old 08-15-2010, 10:28 PM
dms819's Avatar
Default Auto Tranny Rev Limiter?
Quick question, what would the rev limiter be set to on a '93 Trans Am, with an automatic? I know it will shift before the rev limiter if I leave it in drive, but I am wondering how far I can push first gear if I select 1st instead of drive.
Old 08-15-2010, 10:55 PM
RamAir95TA's Avatar
The factory rev limiter is set at 5886 RPM. Also, the PCM cuts fuel instead of spark so bouncing off the factory limiter isn't good.
Old 08-16-2010, 11:17 AM
lt1-xjs's Avatar
Get a tune and have the rev limiter raised. Your shift points are controlled by the governor on the transmission, springs and weights.
