lt1 oil pan help
Most likely hitting in the front on the K-member....I just did this 3 days ago and you have to pull the motor mounts and lift the motor a few inches. I have the trans out and then simpley removed the flywheel so in my case it's a little easier but I almost bet your hitting the k-member on the way down
