Help with leak
Help with leak
My brother has a 94 Z28 with m6. He is leaking coolant from what he said looks like in between the engine and tranny. Are there coolant lines in this area that could be leaking? Do the M6's have the attachment to the radiator for cooling?
If the leak is on the passenger side, check the heater core lines that go into the firewall. If the leak is on the driver side, check the oil cooler (if he has one). This of course ruling out the possibility of a blown/leaking head gasket.
Rockstar
It could somehow be the steam vent coming off the back of the heads. Or a head gasket leak.
Is he absolutely sure it's coolant and not oil? The back of the intake manifold leaking oil is a common problem and is in that same spot.
Rockstar
http://shbox.com/1/egr1.jpg
You see the bolts holding the pipe connected to the back of each head? It runs down the passenger side of the intake and to the radiator.
