Need Advice: Oil in Radiator :-(
When i changed my head and head gasket on the passenger side I torqued it down with 3 passes going up to 65 ft. lbs according to the haynes manual. But when I read on the internet everyone was telling me to do 125 ft.lbs(or somewhere around there i forgot the exact number). What torque specs am I supposed to use? The car ran "okay" with no head gasket leak, but did have an oil leak due from not being correctly sealed at the rear of the intake manifold, it was also missfiring. occassionally the car overheated( i did not let it get past the 3rd tick) but i figured it was due to not properly bleeding the radiator system so i just kept filling it up with coolant thinking the airpockets would soon bleed out by me filling everytime with the car running and bleeder valve open, and i ran like this for maybe less than a month. then the other day i opened the radiator cap and found "chocolate milk".
And if i were to do them again, would i have to remove the head gasket and get a new one or could i just re-use them and unbolt the headbolts, buy new ones and torque them down.
I guess I shouldn't have trusted arp's torque spec of 65 ft lbs when I did my heads? And if you are using stock bolts the correct way to torque them is with an angle gauge not a torque wrench.
You are telling someone to torque his heads to TWICE the torque spec. Think about that for a minute...
i want to see you torque the head bolt down to 125ftlbs then take a pic of the threads in the block, or the block itself, or the bolt itself and show me the twist in the bolt.. thats near dbl the torque needed..
in my life i have never heard of anyone torquing a head bolt to 125ftlbs.. hell a bigblock head isnt torqued that high.. ive built a few engines in my 20+years of hotrodding and i've never seen a headbolt on any engine needing 125ftlbs of torque.. off the top of my head,if i remember correctly a big block head torques down at 75ftlbs..
