LTI individual throttle bodies? EXTRUDABODY ITB FOR SBC?
Old 09-14-2010, 05:53 PM
brad99's Avatar
Default LTI individual throttle bodies? EXTRUDABODY ITB FOR SBC?
i was wondering if anyone has ever built a individual throttle bodies setup for the lt1, if you have would you be able to give me a link to it?
and if not i was wondering if it be possible to fab up a mounting plate the bolts to the heads with fuel injector ports, then weld on these intake runners from a Edelbrock Pro-Flow LS1 intake on then https://ls1tech.com/forums/attachmen...eenshot274.jpg, weld on plates on each runner like this
https://ls1tech.com/forums/attachmen...eenshot288.jpg, ill put the link to the itb for a ls1 i got my inspiration from:
https://ls1tech.com/forums/fueling-i...tb-fab-up.html
and does anyone know about these for chevy small block will they fit on a lt1http://www.extrudabody.biz/servlet/the-238/Chevy-SBC-X-dsh-Ram-Kit/Detail
Old 09-14-2010, 06:54 PM
jaycenk's Avatar
What you are thinking of is simmilar to hilborn EFI setups. http://www.hilborninjection.com/category.asp?Id=255
Very trick stuff and cool as hell looking and to think about. They have a weber style setup that is fuel injection as well as several others. Don't know how well they run but cool none the less.
Old 09-14-2010, 07:00 PM
brucer's Avatar
http://www.edelbrock.com/automotive_...fi_chevy.shtml
Old 09-14-2010, 07:39 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I've thought about it a couple times using an LT1 intake manifold with added dividers in the middle. Then, using 4 stock LT1 throttle bodies. It's a little different, but it would be interesting. There was a thread on an Impala forum that I can't find any longer where a guy used two LT1 throttle bodies on a stock intake manifold with a custom top piece.
Quick Reply: LTI individual throttle bodies? EXTRUDABODY ITB FOR SBC?
