Ls1 injectors
Ls1 injectors
Im building a mild 355 and i plan to run my fuel psi at 60 like ls cars.
i was given a set for free and i know that my stock 93 injectors wil not be enought im just looking to see if any one has done it or if i should just find some 94-97 injectors and run the 60psi
i have the 28's and maybe mild 355 is a little of an under statement it will be a 11.8/1 236/242 590 on a 112 witha 200 shot on a wet kit lol. I just dont want to run out of injector on the motor or should i just buy the svo 30's and run 60psi
At one point I was running 32lbs LS injectors at 58psi, now running 36lbs Trickflow injectors with a stock regulator.
IMO get lbs per hour with injector size NOT regulator. Many of the adjustable LT1 regulators have reliability issues, stock regulator works great.
Basically you can do this but in changing the regulator you are making a compromise to reliability, might never fail, but much more likely to than the stock regulator.
