Getting into the powerband faster/Cam in high mileage LT1?
Ok, so what I've noticed is that my car starts to pull harder staring at 3,000 RPM-5,700(Redline) RPM... I want to know if there is a way to get into the powerband quicker.
For example, I launch the car spin through first and then shift to second and the RPM's drop to 2,000 RPM and my car takes a while to start pulling again? Is it the way im driving it or what?
I know gears will get me there quicker but 10 bolts arent strong and this is my DD. I was thinking 3.90's if i did gears. I have a 96 Formula, so i believe it comes with 3.42's, correct?
Also, a cam would make my powerband lower RPM, and run to a higher RPM, correct?
Please give me some advice.
Thanks in advance,
Kyle
Thanks in advance,
Kyle
this may sound kinda out there but i think it might put it into terms for ya. have you ever played a drag racing video game were have to shift the gears your self? and if ya shift too early from 1st to 2nd it slows the car down real bad ya got to let it bounce off the rev limiter a few times. that is what u r doin to your car in real life. the speed is not high enough to make the shift. even though u are at red line
this may sound kinda out there but i think it might put it into terms for ya. have you ever played a drag racing video game were have to shift the gears your self? and if ya shift too early from 1st to 2nd it slows the car down real bad ya got to let it bounce off the rev limiter a few times. that is what u r doin to your car in real life. the wheel speed is not high enough to make the shift. even though u are at red line
