O-ring on shaft of opti for 93-94 LT1?
Old 11-01-2010, 01:19 PM
94lt1white_bird's Avatar
Default O-ring on shaft of opti for 93-94 LT1?
im trying to help a friend rebuild his lt1 and i cant remeber if there is an o-ring that goes on the shaft of the opti his is a 93 thanks for any help
Old 11-01-2010, 07:32 PM
airfix's Avatar
No theres no O-ring, Just a seal on the back of the opti and another in the timming cover.
Old 11-01-2010, 08:09 PM
Speedy's Avatar
Concur. No o-ring for opti. There is an o-ring for the water pump though.
Old 11-01-2010, 09:04 PM
transam5.7lt1's Avatar
Its a seal, I think its not sold separately, it comes with the timing gasket set.
Old 11-01-2010, 09:57 PM
airfix's Avatar
Are you sure? I don't remember ever seeing an O-ring for the WP.
Old 11-01-2010, 11:09 PM
LT1-TA's Avatar
there is at least one o-ring on the splined shaft cause im in the middle of a rebuild.I check to see exactly where it is tomorrow.
Old 11-02-2010, 06:31 AM
wrd1972's Avatar
The o-rings on the water pump drive (on both ends) are not for sealing, they are for dampening. Any conventional o-ring will work as long as the coupler fits snug over it.
Old 11-02-2010, 07:13 PM
Speedy's Avatar
Absolutely sure. What WRD72 said. And seal for opti, no O-ring like you said. Careful not to lose or damage the little spring on the opti seal.
Quick Reply: O-ring on shaft of opti for 93-94 LT1?
