Le2 rwhp ?
Le2 rwhp ?
whts up guys i talked to lloyd today about my rwhp numbers i made 333rwhp and 333rw tq. i had eldelbrok heads ported by lloyd and got his stage 2 package with his 226/234 109 lsa cam, full exaust 30lb injectors 373 gears 3000 edge stall converter dyno tune, ported intake by lloyd elliot and 58mm throttle body, 1.6 pro mag roller rockers. I was told by lloyd tht i should hve made 370rwhp plus any ideas guys? I have a 95 impala ss
Was the dyno a Mustang or Dynojet? When I had my old engine setup with my EDGE 3400 stall the car only put down 285 at the rear wheels on a mustang dyno but ran 12.3 at 111 so I never got overly concerned with dyno numbers. If the car is running well take it to the track to see how it runs, that will give you the best idea if the car is where it should be power wise.
thanks guys ya it was a dynojet, and the converter was not locked. Ya it runs fine I even replaced my o2 sensors after the run because it was running a little rich. I had new sparkplugs installed no check engine lights what so ever? ya i would definetly like to post a dynograph how can I do so?
I had a set of aluminium edelbrock heads ported. Not sure what the problem could be at all. I talked to lloyd and he said that it should be more as well. Just like i stated 370 plus, i swear it's always something.
ok will do guys, thanks for all the help, and ya but why would the aluminim eldelbrock heads be a weak link, and I have full confindence in lloyd that his product is the truth. I'm really curious as to where it could have went wrong? I'll try and get the graph posted asap thanks again. Anymore help would be much appreciated. And i'm sure that the tune should be good, but i'm going to let you guys look at it
I had dyno lab in marietta GA dyno tune my car for the second time, the first time was after the first install of the LE2 package and the second time was after I had the bottom end rebuilt. Author seemed to be great guys with good customer service from what I have seen so far. I'll check back with them to see what they recommend as well.
