lt1 spark plugs and wires
does anyone have any secrets to doing the passenger side? i can do all the driver side from the top and bottom of the car, but the passenger side looks impossible
i have manifolds. im hoping plugs and wires fixes my problem. im getting suging/hesitation. i did a fuel pressure check, i got 40psi when the pump was primed and engine off, 35psi when engine was at idle, and 45psi when engine was at idle with vacum pulled from the fuel pressure regulator. so im guesing i gota spark problem maybe?
get mechanix gloves, unless you like bloddy knuckles. The worse is changing out the plug in the back of the passenger side. you might also want to consider some high heat plug wires like the accell 9000 wires.
well plugs and wires are done, now it runs like ****. ticking in exhausst, sounds cammed but its stock. barely drives, backfriing alot,, i dont know wth this could be
