What the hell.. why is my belt tensioner way closer to my ac comp than it should be?
Old 11-11-2010, 02:12 PM
Z28Roxy's Avatar
Default What the hell.. why is my belt tensioner way closer to my ac comp than it should be?
Pretty much what the title says, even without messing with the belt at all my tensioner is really really close to the ac comp and really far away from crank pulley.
Old 11-11-2010, 02:31 PM
RamAir95TA's Avatar
Maybe a dumb question, but is the belt installed?
Old 11-11-2010, 02:35 PM
Z28Roxy's Avatar
I tried putting the belt on, it does the same thing. And of course since it's so "off" I can just spin wind the belt around with my fingers :p
I tried comparing it to my TA and there is a HUGE difference between how close they are. I guess my next move I can do is just to try taking the tensioner off it and putting it on my camaro and see if the same thing happens.
Old 11-11-2010, 02:41 PM
RamAir95TA's Avatar
Pics?
And I can't picture it right now, but can it be installed backwards?
Old 11-11-2010, 03:10 PM
Z28Roxy's Avatar
Pics?
No you can't install it upside down or backwards:
Old 11-11-2010, 03:48 PM
ElkySS's Avatar
looks like u need a shorter belt. maybe urs streched
Old 11-11-2010, 05:23 PM
myk
myk's Avatar
Well....as long as there's tension it should be ok, right? I'll crawl under my '97 and snap a 'pic if you want me to...
Old 11-11-2010, 05:55 PM
jaycenk's Avatar
Is that an ATI Damper. It also looks to be a reduction so you will need a shorter belt than stock
Old 11-11-2010, 09:00 PM
shbox's Avatar
Originally Posted by myk
Well....as long as there's tension it should be ok, right? ...
No. There has to be enough tension.
There is a little arrow and some markings on the tensioner that show the range of tension the belt should be within. If it is out of range, you need a shorter (or new) belt.
Old 11-11-2010, 09:44 PM
trilkb's Avatar
i vote the belt is the wrong size
Old 11-11-2010, 10:40 PM
SoxXpupPeT's Avatar
I second this. Try a slightly shorter belt 1-2" shorter. and see how well it fits.
Quick Reply: What the hell.. why is my belt tensioner way closer to my ac comp than it should be?
