Shaft rockers
DRE (the OEM for the high end Comp stuff) make a very nice set as well.
If you convert your heads to perimeter valve covers you can run a lot of different kinds.
If your build is aggressive enough to warrant them then you've already spend a ton of cash and shouldn't mind the small fee of converting to perimeter VCs .
