converting a slipfit header to 3 bolt
Old 11-23-2010, 04:47 PM
speedracer2536's Avatar
Default converting a slipfit header to 3 bolt
I know i have seen this for sale somewhere.. it about 4 to 6 inches of pipe and it slips over the collector and has the 3 bolt flange on the other side
Old 11-23-2010, 04:51 PM
manfred717's Avatar
Why not just get a 3 bolt flange welded onto the end of the header?
Old 11-23-2010, 04:54 PM
they are on the car and im tired of dealing with band clamps.. i would rather just do this..
RamAir95TA's Avatar
Slip-fits are better anyway.
Old 11-23-2010, 04:57 PM
how so?
Old 11-23-2010, 04:59 PM
hashtagBMW
Speed Density's Avatar
Originally Posted by speedracer2536
how so?
A good slip fit and a band clamp thats tq'd right works like a charm. I just swapped back to slip fit after 3-bolt.
Old 11-23-2010, 05:11 PM
RamAir95TA's Avatar
Slip fits seal better (IMO) and give you more ground clearance and flexibility while installing. It definitely depends on the quality of the clamp though.
Old 11-23-2010, 06:25 PM
what clamps do you recomend?
Old 11-23-2010, 06:36 PM
manfred717's Avatar
He speaks the truth, I was about to cut the flanges off of my lt's before I sold my car because they scraped the speed bumps going to my job every day.
Old 11-23-2010, 06:51 PM
wrd1972's Avatar
I will take a proper fitting slip fit any day. Three bolt flanges warp, leak, blow gaskets out and reduce ground clearance.
Old 11-23-2010, 09:52 PM
i have pace setter headers with a 3" collector and a 3 inch y pipe.. what would be the best clamps to get for this setup..
Old 11-23-2010, 10:28 PM
LT1
LT1's Avatar
Band clamps, try this link should work for what your wanting. You'll need a couple of them.
http://www.summitracing.com/parts/WL...5&autoview=sku
Quick Reply: converting a slipfit header to 3 bolt
