Anyone street drive a Spec 4 Clutch?
Old 11-30-2010, 09:54 AM
alan2000T/A's Avatar
Default Anyone street drive a Spec 4 Clutch?
i've got to do something. I street/strip the bird so i need at least a Spec 3 but frankly the Spec 4 is a lot cheaper. I'm a Spec fan after beating the tar out of my current Spec 3 for 7 years!
also, in those choices, 4 Puck or 6 Puck?
thoughts?
(yes, i did search first)
thanks!
Old 11-30-2010, 10:11 AM
3DFORMULA's Avatar
I drive a spec 4, 6 puck springless disc. It was a little chattery at first but easy enough to get use to how to leave the stop signs. I don't drive on the street all that much anymore, but I will only use a spec 4 disc til the end of time, great clutch disc.
Old 11-30-2010, 10:13 AM
good info...seems a 6 puck Spec 4 is a good option for a street/strip ride. All clutches carry a "get used to me or else" factor for a while anyway!
Old 11-30-2010, 10:19 AM
3DFORMULA's Avatar
Yep, I LOVE that yellow pontiac. I remember when (I think) HP Pontiac got that as a New car project. Factory a/c delete correct? It is why I'm in what I'm in.
Old 11-30-2010, 10:22 AM
you've got it, it was in HP Pontiac way early on in its life. I think thats when they covered its "world record" stock 1/4 mile times...back then it was high 13s and that was BAD to the BONE for a stock, off the showroom floor ride.
Old 11-30-2010, 10:32 AM
garage_queen's Avatar
Not a stage 4 but I did just finish up the install of my Spec stage 5, solid hub, sintered disk setup. Have not had it to the track yet but a quick test drive around the block and it chatters MUCH less than my old stage 3, sprung hub, 4 puck. I don't really know if they even have the 4 puck design anymore since they came out with the 6 puck.
I don't recommend a stg 5 for street just stating that chatter was less than my old stg 3.
Old 11-30-2010, 10:34 AM
draggin97s10's Avatar
i drove a spec 4 springless disc on the street 6 puck. i thought it was easy enough
Village Troll
SS RRR's Avatar
LS1Tech 20 Year Member
I did for quite awhile. As stated it's fine once you get used to it.
Old 11-30-2010, 10:37 AM
bigj2717's Avatar
I dd with a 6 puck stage 4 and once you get used to it its not thats bad to drive
thanks guys!
Old 11-30-2010, 12:55 PM
speed_demon24's Avatar
One of my friends had one... It's definitely not something I would want to live with.
Old 11-30-2010, 12:57 PM
that's the kind of info i need now before i buy it. Tell me WHY you wouldn't want to live with it??
Old 11-30-2010, 01:16 PM
Colin91Z's Avatar
If price is a big factor, then I'm not gonna be much help. But here goes anyways....I have a SPEC 3+, and I love it so far. Fairly smooth engagement, very drivable stoplight to stoplight, and grabs like crazy everytime I almost went with the SPEC 4 over the 3+ because it was so much less $, but I don't regret my decision at all, I've been very happy with the 3+
Old 11-30-2010, 01:19 PM
that is good info to consider. I can buy the spec 3 or spec 3+ BUT it is an almost $200 savings to buy the Spec 4 over the 3+...so having a hard time justifying it ya know.
Old 11-30-2010, 01:22 PM
Ton of chatter and it was an on/off switch. Like others said it can be done but I sure as hell wouldn't do it.
Old 11-30-2010, 02:20 PM
Village Troll
SS RRR's Avatar
Perhaps your friend was doing it wrong. The only chatter I encountered was in reverse if the clutch was slipped too much. Other than that it was fine in all forward gears as long as it was engaged quickly. There's a technique to everything. Because of its aggressiveness it cannot be slipped like a regular clutch.
Old 11-30-2010, 03:09 PM
Colin91Z's Avatar
I totally understand, I had a hard time justifying the extra $$$ also. But in the end if figured with amount of money I've spent on this car, another $200 isn't that much in comparison. And street manners were high priority because it spends alot more time on the street than the track.
Old 11-30-2010, 03:30 PM
fex77k's Avatar
There isn't enough formula's on the road, I've seen a few cars mistake them for a 6.
As far as the 3 vs 4 goes. I feel like a cement truck driver when I drive an LS1 compared to my spec 3. I like my spec 3, but I sat in DC traffic for a couple hours and it was killing my leg. What color is the PP on your spec 3? I picked one up for 350 new and it was a older style design, my new one is blue.
Old 11-30-2010, 03:41 PM
gjohnsonws6's Avatar
LS1Tech 10 Year
I have done it,6 puck no springs,Did not have any problems,other than the disc wore down to the rivets in about 5 thousand miles,if that.It was hard for me to feather,it was either in or out,and it did suck in traffic,once it gets hot,its really in or out no other choice.Had to leave space between me and the car in front of me to avoid hitting them.How about the twin disc from Mcleod? good comprimise between street/strip with good pedal
Old 11-30-2010, 05:10 PM
Wicked94Z's Avatar
i did a stage 5 write up on here. the stage 4 is probably a tad more street driveable.
Quick Reply: Anyone street drive a Spec 4 Clutch?
