h/c lt1 low fuel pressure?
I have a 96 lt1 that is sluggish and doesnt run well under load. It is freshly rebuilt but I added trick flow heads, forged pistons and forged rods. My old set up is in my sig. It has good spark and compression. The fuel pressure is only at 38 lbs though. When I remove the vacuum line the pressure does not change. I also had an adjustable regulator at one point and when I adjusted it the pressure never changed. I just put a new fuel filter on it and nothing changed. So I guess the questions I have are: Is 38lbs enough fuel pressure or is that too low? Could the fuel pressure not changing at all even with the regulator at different settings mean the fuel pump is bad? And also it hasnt been tuned yet. I was wondering if some of the sluggishness could be because of the tune?
An upgrade from a 255lph? What would I upgrade to? Do you think my pump could be on its way out? It only has about 5,000 miles on it. But it has been run out of fuel a few times. I already have a safety switch.
Sounds like ur regulator could be stuck on one setting internally.
Can u maybe rig up some type of adapter and attach it to the fuel feed line?
If so, check ur pressure there.
I dont think I mentioned this earlier, but I also pinched the return line closed and the pressure still stayed at 38 lbs. I will have to check the voltage to the pump and check the pressure before the regulator. I have had two different gauges and two different regulators on it and the pressure always reads the same unless I give it throttle. I'm wondering why it never changes?
any way you look at it your fuel system is not working properly..it should rise in pressure with throttle ,that cam set up is also going to demand more fuel and air over stock aswell as a proper tune. so there is no wonder its running shitty for several reasons..
What is a hotwire kit? My pump is wired through a switch with a relay in line.
I thought fuel pressure was supposed to drop with throttle. It has a tune for a cam only cc 306.
It needs a new tune. I know that. But I wanna make sure its right before it gets to the dyno. I am trying to make sure there are no underlying problems causing it to run shitty other than the tune.
just out of curiousity.........is the gauge good lol???? try a different gauge.....and also when you said you had an external pressure regulator on it how did you have it plumbed??? where was the regulator hooked up? and where is the gauge in the system, where are you trying to read the pressure??
Its just an aeromotive adjustable regulator mounted and plumbed just like stock. I tried two different gauges with the same result. I am reading the pressure just after the regulator on that fitting on the fuel rail.
ok thats all good.........just wanted to make sure.........you may have a pump issue where its internally bleeding off pressure yeilding a non adjustable 38lbs........could even be that the plastic hose on the top has cracked or somehting.......do u have the trap door cut so you can easily get in the tank?? also just out of curiousity when was the last time u changed the fuel filter???
