LT1 383 block machine work
I'm doing a 383 stroker LT1... what machine work is needed on the block or what machine work should be done (I know cylider bore .30 over, and stroker crank cleared but what else is importnat and should be done and what is optional and don't really matter
Well the thing is I'm buying a block from someone and what is done to it is bored 30 over stroker cleared lined honed and that's it... Is decking, magnafluxed, and blue printineg important cause I don't thing it has that
You looking to do the typical "I want more displacement" build or are you looking to actually do something worthwhile?
For worthwhile you are going to want to add things like square decking, going to want to consider getting the bore rechecked because the final hone should only be done with pistons in hand.
Magnaflux should be done BEFORE any machining to make sure you are starting with a good block. Blueprinting is making sure clearances are all right, you could halfass it and cross your fingers.
Keep im mind my 383 block was already clearanced and .030 over and never run except on the engine dyno. You wont need a half fill and could stay with 2bolt mains but everything else I would do
De-plug block, tap front galleys if not already done, remove cam bearings, wash and fill 1/2 way, hone cylinders minimum with deck plate, re-balance, pin fit rods and pistons and check large end and hone if nessessary, Assemble short, mount pistons on rods, check oil clearance (mains and rods) and file fit rings, Install splayed caps, align bore and align hone mains
