spark plugs? advise please.
I have full bolt ons and a madz28 tune and need new plugs. I had tr55's or tr6's, wich ever is hotter. It never idled perfect and I was wondering if a delco double platunum would be better as that is what it had from the factory being a 1993. Or should I go with the autolitexp's? Thanks in advance for the advise.
with virtually any plug of the correct heat range the car should idle fine.......i've personally had great luck with the tr55 plugs in stock motors.............i've been running a much colder NGK in mine also now and have had good luck.............sounds like your idle issue is caused buy something else other than the plugs......
My question is, what makes you think you need new plugs?
Well I already know what the problem is, the tune is just pig rich kn warmup, I just thought a better plug might help.xp'i think im gunna try the double plat acdelco or xp's. I know I need plugs because I pulled one and theyr fouled because of how rich it runs when cold. I sounds cammed lol. I threw it on the wideband and confirmed my thoughts on the tune, I will probubly do some data logging with ion.
Yep I know. I'm actually a mechanic. I just wanted to see what opinions on brands are for my setup. I always learn from you guys, like I would never used ngk plugs for anything but a honda until I talk to you guys. I just don't have time to fix it with a 4 year old and newborn and working fulltime plus sidework all days of the week.
