Stock FPR Failing?
OK. I just want to do some tests with my fuel system to make sure it has stable fuel pressure before I go and take it in for a tune (speed density)
What is the best sure-fire way to test it then? Will hooking up a pressure gauge suffice?
well my main concern is that it is letting too much pressure go by. My plugs are a little darker than they possibly should (lots of idle time tho).
Everything may be working just fine and its just how the open loop/SD tune is. Yep, im in race car denial
Just a walbro 255. I just rented the tester today...
So the plan is: Going to check fuel pressure at idle and pull the vacuum line off. If I see any crazy high pressure (like 50lbs) then I know something is up and I will replace the reg. If its around 45 I will leave it be
havent been able to do anything with the car. Living in Michigan makes it too cold to even open up the garage. I will try to test pressure next week (suppossed to get warmer)
I'll let you guys know my idle fuel pressure and then the pressure it goes to when I take the vacuum line off.
so I got around to testing this today.
At idle I had about 46-48 psi and then once I took the vacuum line off it went to 50 psi or just a tad over. Once I turn the car off the pressure is immediately gone. Nothing is being held in the line it seems. When I touch the throttle off idle (less than 3000 rpm) it seems to bounce around a bit, even dropped to below 40 psi for a split second... I have a Walbro 255, so fuel is not an issue, especially at only less than 3000 rpm
You guys think its safe to say my FPR is failed or in the process of failing?
-I dont think I have a leaking injector, because mine were all flow matched and tested recently. But thanks for your input, I think I am going to check them for leaks anyway
-I hear some pumps dont have an internal check valve. What is it even there for?
I ended up ordering a stock new FPR and im gonna put it on today. There is really no way of knowing whether it did anything or not, but I guess its peace-of-mind if anything
My very reputable tuner did say that if a FPR is failing, then it will cause the rear cylinders to run a tad rich, and my richest plug is #7, followed by #8 in a close second.
Anymore input on this? I already pulled the fuel rails apart so it looks like im going to replace the FPR either way.
well guys, as you know I put a new regulator on and finally started it.
I am very happy with what I found. Idle is at a steady 42-44ish psi, compared to the 50psi I had.
If I keep the vacuum line on and give it revs, it will drop down a bit and get jumpy and somtimes go down to 30psi for a split second. But if I have the line off, and give it a rev it will hold steady at constant pressure all the way through the rpm range.
WTF
I capped the vacuum line off entire and capped the regulator and it held steady through the entire RPM range. Did not flinch one bit. Should I just keep a vacuum cap on it? Isnt a constant/reliable/steady pressure what you want?
WTF
Put the gauge up under the wiper arm where you can see it and go do a WOT run. If it drops below 39psi you have a supply problem plugged filter, weak pump. It takes pressure and volume. Just because the pump has pressure at idle and free rev doesn't mean it can supply the volume of fuel to maintain the pressure under WOT.
I need to know if its good or normal for it to get all goofy and drop off when I rev it with the vacuum line ON?
