3200 edge stall
3200 edge stall
I am going to be buying a edge 3200 stall for my 1997 TA. I am wondering what other mods I should do to the trans; I already have a true cool trans cooler, but what fluid should I use and should I change any seals. Also will this converter provide a huge advantage over stock and will it hurt the way it drives around town?
When accelerating your mpgs will decrease quite a bit, but your cruising mpgs will not change with a lockup clutch.
First go bigger, 3600 is where its at. I haven't noticed a difference in the way mine drives around town with the 3.73s. Its fine at low speeds and when I want it power is there. Definitely a shift kit. My trans is stock with 200K miles and still strong, no signs of slipping. As far as fluid this is one area most will tell you to cheap out. Plain old Dex/Merc of any brand will work fine, Im using Castrol in mine. Stay away from synthetic fluid
