Bad Fuel Pump and Low Operating Voltage. Any relation?
I am very certain my fuel pump is going out. I have not had a chance to check the pressure, but the car is showing the classic signs of fuel pump failure.
However, i was driving back from class today, stopped at a red light, and realized that my voltage needle was sitting right on the outside edge of the red markers on the gauge.
Would a bad fuel pump suck extra volts? Or is the Florida heat just killing my altenator?
It has been hot as hell here latley, so my altenator may just be going out too. Got to love the Canadian Parts Clock..lol..car hit a 100k and now the parts replacing shall begin. Ill have the altenator checked at the parts store tomorrow, i just wanted to ask here and see what any of you LT1 Veterans had to say about it.
I guess the only reason I asked was to get an understanding of what bad components could affect others, if at all.
well you WERE at a red light when the needle dropped with everything on, im not surprised. i wouldnt worry. you just werent spinning the alt enough to keep up the power for the headlights, ac, radio, brake lights, etc happens to me all the time if my car is on full load and idleing
Yeah I realize how dumb that question sounded..lol. I know that the needle can drop at idle while sitting at a red light. But even with all my accessories on its never dropped THAT low. The alternator is fine and I have a brand new Red Top, so it just made me curious.
Since the fuel pump has been giving me grief I figured I'd ask and see if a bad pump could in fact suck extra volts. Never hurts to lear when one bad component could affect another.
That's MISTER MODERATOR
A bad fuel pump drawing excessive current would blow the fuse shutting down the engine. This fuse should be 20 amps.
Low running voltage will cause the fuel pump to run slower and possibly not produce enough PSI that's needed which would reduce performance.
I would start by finding out why your voltage is running low.
Checking your fuel pressure is also a good idea.
A kit like this would look nice in anybodies tool box:
http://cgi.ebay.com/ebaymotors/FUEL-...motiveQ5fTools
Well nothing is for certain untill I get a pressure gauge on the car. I adopted a neglected pup this month and had a pretty hefty vet bill to get him up to speed on shots and such.
So the fuel pressure gauge will have to wait untill the 1st of May.
But the car has been harder and harder to start. When i turn the ignition the pump never turns on. If i switch the ignition off, then back on it will start..rough for a couple seconds (maybe 3 sec.), then it runs and idles fine. I also get a slight smell of fuel after the car finally starts.
So thats why I originally said that I have classic fuel pump issues..lol
Could be dirty MAF, spray clean with correct MAF Cleaner. Don't use oiled air filter.
I will definitely check the injectors and MAF. Still have to wonder why the pump doesn't turn on when the iginition is turned on during the first try. Worst case is that I have a combination of fuel system issues.
Sucks that I have to wait till the first of the month to buy my pressure gauge..lol...because everything is simply speculation untill then.
