exhaust manifold bolts snapped
Old 05-20-2011, 09:50 PM
77ihwheeler's Avatar
Default exhaust manifold bolts snapped
I was taking my exhaust off earlier today and where the y pipe bolts to the exhaust manifolds I broke three out of the six studs what's the best way about getting the rest of the studs out
Old 05-20-2011, 10:31 PM
shbox's Avatar
If there is anything to grab, heat them (stud only) with a torch until cherry red, then douse them with water to cool them quickly. That usually breaks them free. If broken off flush, they will have to be drilled and extracted.
Old 05-20-2011, 10:40 PM
There is some showing but they are still in the car and if I don't have to take them off I would prefer that and I don't have access to a torch without removing them or renting a trailer and towing it and I'm in the middle of putting in a new trans
Old 05-21-2011, 01:01 PM
robmnrd's Avatar
No joke, breaking them is the best way. I asked this same question when I went through the process of pulling the exhaust apart, and was told to just break them.
I then read many months later that breaking them is far easier than not breaking them. You didn't say why you were pulling the exhaust, but I'm going to assume you're not too worried about keeping it in good shape, so just do whatever is easiest/quickest - breaking them. lol
Old 05-21-2011, 02:43 PM
I took the exhaust off cause I am replacing the transmission... I did break them. And now I am trying to figure out how I am supposed to put it back together
Old 05-21-2011, 02:58 PM
gcouse7's Avatar
Default exhaust bolts
I drilled mine out and just got a bolt to hold it together when it came time to assemble. Good luck
Quick Reply: exhaust manifold bolts snapped
