AIR delete on a 94 LT1?
Yea im trying to. The pump isn't located under the driverside headlight on my car. I think its right below my blaster because that's where both of the lines run to from the exhaust manifold
Its pretty simple to remove...just buy some plugs for the manifolds or cut the stock fittings. I can't remember if there are any codes for the air pump but you can have it deleted off the computer.
The following users liked this post:
sully91rs (08-04-2024)
So I called napa and autozone asking for an oil drain plug for a 2000 dodge ram 3500 cummins/ M22 drain plug. Napa had to special order for $20 each and autozone was $50!! Antone else get this too? Any cheaper alternatives?
I know the feeling. So regardless of !AIR, the fans would not come on without the AIR relays being pulled?
After reading around, everyone said to buy P/N: BK 7041378 for the M22/1.5 drain plugs. I bought 2 at napa for like $8/each.
They did not fit, the bolt was too thick. So much for that. Now I am trying to find the right size bolt so that I can get it tuned out soon in a mail order tune... did I miss something?
Switched to m18 in 96.
This is the first time working on this situation. I am changing the water pump in my 94 Z28 it has the air pump and bracket. I am reading this can be deleted. Do you need to take out the metal tubing that runs from side to side under the block? How many of the M22 drain plugs do I need? Thanks in advance.
