Tps (96 z28)
pressure test it! wallmart sells the stuff cheap that will charge it and has a gauge to see what psi its running, its in a blue bottle.
If its turning off and on at idle it could just be low, or your TPS could be throwing weird signals making it think you are going wot or something..? im not positive about that but im pretty sure that the two problems arnt going to be related..
If you go ahead and replace the TPS first you can rule it out just to be safe, TPS cost about $8 from autozone and takes like 30 seconds to install.
