Are all LT1 crank hubs the same??
im pretty sure the b-bodies are a little shorter. i used a b body motor with the f body accesory brackets and the belt likes to jump back towards the motor a notch or two
Moderator
No, because CPS on an OBDII car would factor in to this making it shorter than a OBDI cars hub due to the 4X reluctor wheel. So a 96+ LT1 would be shorter than a 93-95 cars with no reluctor wheel, making those two different right off that bat.
Looking at Jegs, B-bodies, 93-95 F car and 96 F & Y cars are all different part numbers
4x, 95, 96, crank, crankshaft, difference, differencens, differences, differnce, hub, hubs, lt1, lt4, reluctor, threads, wheel
