Blown Transmission?
Blown Transmission?
Hello I was racing last night with my LT1 A4 in west Miami doing 1/4 passes. with some ricers. on the last run i did a burnout 5100 rpm and seemed fine, i finished that 1/4 but then when i had to turn around in reverse the car would not go anywhere. it would just sit there and rev to only 2000rpms in reverse even when i pushed the pedal all the way down. it would not go past 200 rpms. then i tried Neutral and it goes foward only in 1 gear and hits 6200rpms. then i put it in drive it drives fine it shifts when its supposed to. and last i put it in park and as soon as i put it in park the car wobbled back and forth and sat there tried to rev it and also only went up to 2000rpms. In drive it drive great normal. it revs and changes gear at whatever rpm i want it to. im guessing it could be the toque convertor but not sure. any help.
thanks, Aaron
thanks, Aaron
