Panhard bar????
Panhard bar????
Has anyone had any issues with the Panhard bar? Mine fell off yesterday...I rigged it enough to make it home from work(with a Lanyard, LMAO). The threads on the end of the bar are toast so I am thinking I will need to buy a new one. How the heck do you tighten that thing up? Do you turn the nut on the part that the Rod screws in to????
What brand of PHR is that? I would bet that if you called them and sent them a picture of what happened they'd replace it for free. Chances are they are a site sponsor and don't want this kind of negative exposure so I'm sure they'd help you out.
It looks like you have a single adjustable bar and the jam nut wasn't tightened? You are supposed to disconnect the end link, turn the hex piece in red so the bar is the proper length, then reconnect the end link and tighten the jam nut. It's kind of hard to tell which type you have.
It is an Edelbrock...I took one side loose and tried to put the bar back in but it wouldn't thread, and even if it did, it is going to be hard to get the piece I took off to line up right...Hmmmm
agreed with everyone. hard to see exactly what type you have but it looks like it was adjusted too far.. although if its adjusted too far id think you would have noticed because im sure the rear would be pretty far off on a max adjustment. if it was sitting on the last couple threads.. take it off the car, get a pic of the whole thing and put it back up. maybe it will just go right back together.. if not $100 new one is easy enough
