ls1 ir led on lt1 ?
Where are you seeing all this talk?
Basically......6-8" straight shot from filter to throttle body with no turns > CAI kits for LT1s which have two 90* bends and over 24" from filter to TB
Just guessing on the distances but I feel they're conservative.
LS1 lid helps throttle response and gives documented gains in HP across the RPM range. But you have to cut your core support to make it fit.
so all i have to do is cut the support ? any pix on this nice if some one had a post on here about this maybe like a sticky so this ? stops geting asked over and over.
Ls1 and lt1 cars use different core supports that's why the ls1 lid isn't a 'bolt on' swap.
There is a ton of info on this site if you search for it. At least 3 write ups I would say. Its a pretty involved process.
I'm debating right now if I should try it or just do and 'over the radiator' style intake so I don't have to cut my ss hood.
ok what about set ups like this
http://www.youngsfbody.com/inc/sdetail/171/17968
http://www.youngsfbody.com/inc/sdetail/171/17944
i see there is a lot of cutting and i realy don't want to go hacking on a nice car and from what some ppl say the again is not worth it i guess i tryed to use the search but just got alot of junk wee thnks for any help
