Manual to Auto wiring harness
Old 11-15-2011, 02:15 PM
B-Rad420's Avatar
Default Manual to Auto wiring harness
I am changing my car from manual to auto. I have found a Z28 here locally that is the same year as my car (1995) and plan to pick its wiring harness. What I am wondering is can I just cut off the auto trans part and solder it into my harness or do I need to get the whole harness from the engine, ecm, and trace the wires into the fender and remove them from the body? Thanks
Old 11-15-2011, 04:09 PM
shbox's Avatar
Cutting stuff off kind of defeats the purpose, because you want those wires to run to the PCM. Swap the whole harness IMHO.
Old 11-15-2011, 04:38 PM
AChotrod's Avatar
Listen to Rob. He knows what hes talking about. Or you can put in a 700r4, TH350, Th400 and not worry about any of that.
Old 11-16-2011, 11:37 AM
B-Rad420's Avatar
I would love to do a 700-R4 swap but I already have 2 real nice 2000 year model 4.3L S-10 trans. I have been told by PCMForless that he can make my 1995 ECM shift and provide a good signal to the speedometer for that trans also.
Old 11-16-2011, 11:45 AM
flame's Avatar
If you can get the engine harness that is the simplest. I added in the trans plug to my harness when I swapped to auto. You will also need to add in the wiring on the auto shifter for reverse lights, p/n signal to pcm and move the wires from the clutch start switch for p/n starting.
Quick Reply: Manual to Auto wiring harness
