how much horse power is my car going to make
Old 11-30-2011, 09:29 PM
tt383lt1's Avatar
Default how much horse power is my car going to make
i have a 383 lt1 with 210 afr competion heads. 8.1 compression custom tpis boost cam, 58mm throttle body 120lb injector. 24x coversion with a aem driver box. twin 72mm turbos. water to air intercooler, going threw a built th400 trans with 3500 stall. 3.25 gears in a 9" rear. and 28-13.5-15 tires
on na with 11.1 compression and 42lb injectors it made 580 on the crank at 7200 rpm and now i lowered the compression and put turbos on. and i was wondering how much i lost going to 8.1 compreesion from 11.1. and how much i will make off boost. it put down 550 at 3 psi on the wheels when it was tuned and we blew the header gasket out. now i have locking header bolts.
so
Old 11-30-2011, 09:55 PM
defaultexistence's Avatar
Bout tree fiddy
Old 11-30-2011, 10:22 PM
marc97taws6's Avatar
1300rwhp...
Old 12-01-2011, 08:55 AM
05HD's Avatar
Need all the specs on the turbos to give you an accurate guess. I assume you are aiming to run all of the boost? Or just some of it?
Old 12-01-2011, 09:21 AM
QIK E's Avatar
Originally Posted by defaultexistence
bout tree fiddy
dammit monsta
Old 12-01-2011, 09:28 AM
quik95lt1's Avatar
Bout tree fiddy
bahhahaha woman did u give that monsta money!?
Old 12-01-2011, 09:29 AM
quik95lt1's Avatar
and my guess is who cares lets see what its does at the track....lol
Old 12-01-2011, 10:08 AM
ahritchie's Avatar
LOL no mention of how much boost Assuming somewhere between 1-30 pounds of boost should make precisely 763 RWHP 811 RWTQ going by my calculations
Old 12-01-2011, 10:11 AM
sweetbmxrider's Avatar
Bout tree fiddy
I came in here just to post this, well done.
Old 12-01-2011, 12:06 PM
http://www.youtube.com/watch?v=9GIkn...e_gdata_player
Old 12-01-2011, 01:10 PM
Tony Shepherd's Avatar
It will make 800 rwhp but you will post on youtube that it makes 1400rwhp. I can already see it!
Old 12-01-2011, 03:12 PM
gimmie11s's Avatar
It will make 20 hundred point 33 thousand HP on Octember 32nd only.
Old 12-01-2011, 03:45 PM
quik95lt1's Avatar
touche
Old 12-01-2011, 08:26 PM
tt383lt1's Avatar
i want about 1200 to 1400 crank horse when done if i said 1400 rwhp i meant crank. but hoping about 900 to 1000rwhp im going to max these injectors out until i can get bigger ones
Old 12-02-2011, 04:32 AM
BIGCAT7274's Avatar
lmao
Old 12-02-2011, 11:04 AM
gregrob's Avatar
Why in the hell did you go so low on compression?
It sounds like you just picked that number out of your *** instead of defining a fuel and boost number to stay with in the octane limits of the fuel, then choosing a compression number.
Unless you plan to run 30lbs on 93 pump gas... lol
Old 12-02-2011, 03:54 PM
tt383lt1's Avatar
plan is about 25 psi. and tpis did the set up for boost. i told clay what i wanted and he picked out the compression and cam for the boost
here is a link about picking compression i just found
http://www.turbo-mini.com/70947.html
Old 12-02-2011, 05:27 PM
BIGCAT7274's Avatar
if you don't mind me asking. how fast have you gone with a boosted combination?
Quick Reply: how much horse power is my car going to make
