Rocker torque specs
Rocker torque specs
Putting my heads back on and the auto parts store doesnt know and i really need to know soon if anybody could help me if you know what the rocker arm bolts are supposed to be torque at
if your talking about the studs that screw into the head, its 50ft/lbs and make sure to use threadlocker, if its the nuts that hold the rocker onto the stud, there is no torque spec, you adjust each one individually.
google rocker arm adjustment.
There are no "rocker arm bolts". So are you asking about rocker studs or the nuts actually holding the rocker arms on the studs? If the latter, LOL. If the former, thread sealant and 50 ft/lbs.
