Impala SS track results
New motor track results. NA, 4400 lbs with driver, DA 958. Still on pump gas tune. Full exhaust, full interior, AC.
Updated track results. Went back today for day 2 of grudge wars. DA was 602. Hit my preliminary NA goal for this motor. I think there is more left it in similar or better air.
Chett
You damn right there is still a lot left on the table. With your setup and some more tuning on the old FAST the car will run 11.0's or high 10's N/A. Setup right on nitrous you will kick my ***!!! Great runs I would recommend going to a 28" tall tire though. On my 9.92 pass the car was on the rev limiter at 7000 for approx 200 ft on a 28" tall tire.
Chett
And I seriously doubt that I will kick your *** on nitrous lol. You have your combo completely dialed-in and I know you will not be sittiing still. I am just scratching the surface right now.
Thanks Frank!! You are right on all counts. I tried these 26" tires NA to see what would happen and everything picked up. Cheap way of changing your gear ratio. The 28" tires will go back on with the bottle.
I would die for your top end setup. At the time I setup the car I just didn't want to part with extra 1500 for the jesel's and lifters and the springs and push rods to run a solid roller. And on the stock PCM it would have useless. Couldn't rev it high enough to get all it had to offer.
