1996 camaro z28
Old 01-12-2012, 04:21 PM
Bosque2006's Avatar
Exclamation 1996 camaro z28
This is my first camaro and I really love it. I bought this car last week for 1800 dollars with 147k miles and a 6 speed. I'm having a couple issues with her the guy before me installed a push start but you still had to put the key in the ignition and turn it on and then press the push to start. Well 2 days ago after work I went to start the car and put the key in the ignition and press the push to start, it cranked twice and then just stop. It will not turn or even crank anymore. It makes a click sound and that's all. I would appreciate any help this is my dd. thank you. Before anything happen the car ran fine.
Old 01-12-2012, 04:25 PM
my number 1 hater's Avatar
battery? or cable end?
Old 01-12-2012, 04:36 PM
GreenBlood55's Avatar
Sounds like dead battery to me. Any chance you left the key in the on position and it drained the battery?
Old 01-12-2012, 04:51 PM
lt1slowz28's Avatar
this.
might as well, get rid of the push to start, i mean... you have a set of keys and a working ignition circuit...
Old 01-12-2012, 05:01 PM
Bosque2006's Avatar
I'm have the battery charging now. So hopefully that's it. Yeah I'm getting rid of the push to start. I'm gonna post some pics of the car. Thanks for everyones help
Old 01-12-2012, 06:32 PM
lt1slowz28's Avatar
if that's not the issue, once the battery is charged the starter may either have a bad connection or may just be bad itself.
Old 01-12-2012, 08:50 PM
bizerk1's Avatar
this is what happend to me, but i dont have push button start. battery ended up being dead, had it charged from autozone, it checked out ok a few weeks later, even though had been sitting b.c engine bad i went to crank it and it did clicking. battery is dead and bad, so I need to get new 1
Old 01-13-2012, 10:34 AM
Bosque2006's Avatar
Yeah the battery charged up and still was just one click from the push to start. I'm guessing it has to be the starter then. Is there anyone I could have broke it with the push to start?
Old 01-13-2012, 11:56 AM
lt1slowz28's Avatar
if it clicks it is getting power, I would double check the wiring, starting from the switch and tracing it all the way to the starter.
either that or you only got a surface charge.
though, once I had checked everything, but for some reason the crazy amount of oil from a leak I had was ruining the grounds the starter needed once cleaned up it worked fine.
Old 01-13-2012, 01:37 PM
Zlow28's Avatar
try jump starting it. This will narrow things down a bit
Old 01-13-2012, 02:02 PM
Bosque2006's Avatar
I tried jump starting it and still no work. It just makes one click from the push to start and it sounds like it's coming from below the tranny. It's weird. The way they did this car it's all rigged up and I'm trying to figure out what goes to where.
Old 01-13-2012, 02:22 PM
Bosque2006's Avatar
Also it keeps blowing the eng sensor fuse when I push the push to start button
Old 01-13-2012, 03:20 PM
Rockstar
Johnny-LT1-runner's Avatar
That narrowed it down a lot. Sounds like the starter solenoid.
Old 01-13-2012, 03:41 PM
Zlow28's Avatar
Well you know for sure its not the battery.
You can start by checking the ginition coil wire. Its the top one and shortest wire coming from the opti somewhere around the drivers side water pump gasket. If it gets loose, itll keep the car from starting.
Do you have long tubes? Your o2 sensors might be getting burnt and causing a short, causing the eng sensor fuse to blow. Or maybe a bad ground.
Old 01-13-2012, 04:13 PM
lt1slowz28's Avatar
well, before you go chasing spark problems that might not exist... Try to get the starter going... check the wiring to it as stated before, make sure all mating surfaces are clean and it's bolted up nice and snug.
sounds like the bendix is actually engaging but doesnt have enough ***** to turn over... have you tried to see if the motor will turn over by hand? will it catch and fire from a nice little push start?(we've all done it at one point or time in our lives)
Old 01-17-2012, 03:02 PM
Bosque2006's Avatar
I changed the starter and still nothing. It doesn't even click anymore. I don't know what it can be
Old 01-17-2012, 03:14 PM
ahritchie's Avatar
Sounds like the previous owner ghetto rigged this push button start crap and now you have these oddball electrical issues.....Push button start... take that pep boy **** off the car and get it back to STOCK; that will greatly help your troubleshooting.
Old 01-17-2012, 03:23 PM
Bosque2006's Avatar
I'm trying to figure out how to put it back to factory. He has a orange wire cut and a red wire cut to the push start
Old 01-17-2012, 04:19 PM
Bosque2006's Avatar
So I fixed the car. It was a cigarette fuse that was blown. What a pain he rigged the push to start with that. Glad it's fixed now
Old 01-17-2012, 04:20 PM
Im thinking your going to run into a VATS problem because of this. Get your wires figured out a make sure everything is connected to the right places. If VATS is fubar, car wont do crapola.
Quick Reply: 1996 camaro z28
