how to figure out the cam specs
Old 02-01-2012, 01:28 AM
tt383lt1's Avatar
Default how to figure out the cam specs
i lost my cam sheet for the specs, how do you mesure the cam to get the specs. the engine is out of the car. im redo all the seals and powdercoating the engine again. and im going with another tuner next year. so i like to figure it out thanks
Old 02-01-2012, 06:06 AM
Wicked94Z's Avatar
degree wheel and a cam checking fixture, it send it off to a camshaft company and have them check it.
Old 02-01-2012, 06:36 AM
96TransAmboosted's Avatar
Im sure a dial indicator could help determine lift.
Old 02-01-2012, 06:43 AM
shbox's Avatar
If you know the cam model (surely, you know what you bought), just look it up the specs from the manufacturer.
Old 02-01-2012, 06:54 AM
tt383lt1's Avatar
its a custom boost cam from tpis.
Old 02-01-2012, 07:34 AM
quik95lt1's Avatar
it can be measured with a degree wheel and a dial indicator and base as wicked said above........ive done it b4 works well
Old 02-01-2012, 07:36 AM
tt383lt1's Avatar
i think i found out how. your right i need a degree wheel and dial indicator. thanks everyone
Old 02-01-2012, 04:32 PM
BIGCAT7274's Avatar
make sure you check it at 0.050 lift.
Old 02-01-2012, 05:39 PM
tt383lt1's Avatar
yep i found a site that tells you exsactly how to do it with a dial indicator and a degree wheel thanks everyone
Quick Reply: how to figure out the cam specs
