should I get a new radiator?
Old Feb 1, 2012 | 10:57 AM
dhanks56's Avatar
Post should I get a new radiator?
Just bought a 95 T/A a few months ago, and the coolant looks like brown rust. Thinking of buying a new radiator so flush and start with a new system, should i get one with aftermarket fans? If so what is the best size fans to get? Or should i just stick with the stock fans? thanks
Old Feb 1, 2012 | 11:14 AM
ULTIMATEORANGESS's Avatar
Smile
maybe take it to a radiator shop and have them inspect it. if its ok hAVE it cleaned up. if not im sure theyll have a new one for you.
Old Feb 1, 2012 | 11:56 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
If you find that the radiator is too clogged to be restored by simple flushing, then chances are the heater core isn't too far behind.
But personally, if there are no leaks and no overheating issues, I would just flush the system and see how things go.
Old Feb 1, 2012 | 12:02 PM
513camarors91's Avatar
i would get if flushed first and then go straight how and replace it....get as much of the block as you can
Old Feb 1, 2012 | 01:43 PM
dhanks56's Avatar
It over heats when I'm not driving, as in waiting at a light or the drive thru.
Old Feb 1, 2012 | 03:21 PM
hows your TSTAT?
Old Feb 1, 2012 | 05:29 PM
2win_SS's Avatar
What's TSTAT?
Old Feb 1, 2012 | 06:38 PM
jimmyblue's Avatar
Moderator
When is the last time you cleaned out the debris that these
bottom-feeder cooling systems catch in the fins?
