Feedback on these cam specs.
Old 02-12-2012, 04:58 PM
cycletech's Avatar
Default Feedback on these cam specs.
This is the cam spec card for the camshaft I am thinking of using for my 95 LT1 355 build. I am using trickflow 23" heads already ported and compression will be around 11 to 1.. I will be converting to carb intake and running 850 holley carb. Just lookin for feedback on this camshaft.
Old 02-12-2012, 05:06 PM
RamAir95TA's Avatar
Why so low on the compression? Most performance builds should target the high 11s to mid 12s on the compression. The LT1 can easily handle the added compression due to the reverse flow cooling.
The cam is also, IMO, a bit on the small side. A similar grind, the XE503, is most notably known for being one of the best cams for use on stock heads, much less ported Trickflow's. Either step down the heads or increase the size of the cam, IMO.
Old 02-12-2012, 05:27 PM
joelster's Avatar
That cam is tiny for those heads.
Old 02-12-2012, 06:39 PM
96lt1m6's Avatar
That is ALOT of carburetor for that set up, I personally would go to a 750cfm. #4779 I believe is the number and a 1" spacer........
Old 02-12-2012, 07:33 PM
96capricemgr's Avatar
What intake are you running? I believe this plays into cam selection.
Far as compression I think with a carb you probably do need to stay a little more concervative.
You also did not tell us if this is a street car or a track car?
Old 02-12-2012, 10:34 PM
Wicked94Z's Avatar
that size cam will want a dual plane and a 750 carb.
Old 02-13-2012, 01:12 AM
gregrob's Avatar
Nah brah!
Old 02-13-2012, 06:02 AM
nvrending97ws6's Avatar
Way to small man I'm running 227/233 .544/.569 on stock cubes ported stock headed car and it loves it
Old 02-13-2012, 10:44 AM
sweetbmxrider's Avatar
We all know that stock compression is best for this. Let's not mislead the OP down a path of changing things and not running 12s.
Old 02-13-2012, 11:21 AM
RamAir95TA's Avatar
What's your problem?
Do you have anything constructive to add to this post, or are you just gonna keep on trollin' along?
Old 02-13-2012, 12:38 PM
wrd1972's Avatar
huh...............
Nobody keeps 10.5 after a rebuild or if they do they are leaving power on the table.
Old 02-13-2012, 12:57 PM
draggin97s10's Avatar
First i would up the compression to around 12 or more. Second i would run a bigger cam some where probably in the 232/238 range w more lift as well. and if its gonna have a single plane which was not specified, id close that lsa down to 108 ish
Old 02-14-2012, 08:24 AM
cycletech's Avatar
This will be a street car.. I will be running the gm carb intake manifold, and really thing of running e85 which will help with a little more power. Should I call LE and order a camshaft from him? Any help is greatly appreciated! The heads are the 62CC heads.
Old 02-14-2012, 08:51 AM
Heads need to be milled down to make the chambers smaller. Call LE and tell him your goals.
Old 02-14-2012, 08:52 AM
1963SS's Avatar
Well, since it's a Comp Cam card It will spec the lift with 1.5 factory rockers. If we get realistic and assume you're going to go 1.6 like most of the free world then the lift goes to .574 on the intake and .570 exhaust. That's a good amount of lift and with the duration's and LSA I think that would make a killer, daily driven, street cam. You should have plenty of power down low where you normally use it and still be able to get-er-done on the big end.
In other words a broad power band. That's a good thing for a street car.
I agree that you've chosen too much carb for your build. A 750 will be plenty for any power you're going to make and will give you better throttle response. This will be especially true on a double plane manifold like the Performer RPM. The Performer RPM will easily make big power at 6500 RPM. Since the double plane splits the plenum volume in half (basically) you can get away with a bit more carb.
The cam you've chosen, a 750 CFM on a double plane will easily pull well from 2000-6500 and it just don't get a lot better on a street car that will be capable of kicking some serious ***.
Old 02-14-2012, 09:58 AM
I don't appreciate the attitude. Let's not suggest doing things other then stock because stock is best and people run 12s doing that.
Old 02-14-2012, 10:33 AM
1963SS's Avatar
Now boys.....play nice. This thread is about the OP's question about cam choices and not about whipping them out and having a measuring contest. When in doubt about what to post we should all just go back to post #1 and respond accordingly. A healthy discussion is great but the snarky remarks don't really help at all.......Right?
Old 02-14-2012, 11:24 AM
RamAir95TA's Avatar
I made no snarky comments. sweetbmxrider is sour because I recommended a gap of .050" for a stock LT1 car and in his mind that's BLASPHEMY.
Old 02-14-2012, 08:16 PM
cycletech's Avatar
Comp cam told me that cam runs between 1800rpm and 5600rpm range. I purchased some pacesetter longtube offroad headers. I am hoping to run high to mid 11 sec passes at the track with my setup.. I am switchin to turbo 400 trans with a 3.73 gear with 10 bolt. oh, and run a neil chance 3200-3400 stall.
Old 02-14-2012, 08:24 PM
bowtienut's Avatar
That cam is easily capable of giving you 11 sec performance. You might want to aim a little higher for converter stall though, depending on what other duties the car needs to handle.
Quick Reply: Feedback on these cam specs.
