Connecting Rod Recomendation
Here is lunati's 6 inch h beam at $500 http://www.lunatipower.com/Product.aspx?id=174&gid=173
Here is callies rods selection
http://www.callies.com/compstar/connecting-rods/h-beam/
Don't skimp out on a connecting rod, especially if you plan on pushing 800 horse or more. Also I don't know what you want i beam, or h beam... I beams are stronger and alot of times don't require any clearancing on the block as opposed to h beams. hope this helps
If you choose an H-Beam on a stroker be careful on your rod bolt selection. Our blocks don't have too much clearance before hitting water, and it varies block to block.
callies compstar or carillo k1's with arp 2000 bolts will do that all day long.........also maters on the expected rpm range............i run olivers in mine but its overkill.......i did it for rpm capability and weight savings the olivers are 100+ grams lighter than a h beam and FAR stronger
