AFR 210 LT4 heads... front oil drain back holes??
Old 11-24-2012, 02:27 PM
TWS
TWS's Avatar
Default AFR 210 LT4 heads... front oil drain back holes??
On my AFR 210 LT4 heads, the front oil drain back holes are blocked - literally by the block. Looking at it, my engine builder and I observed that it looks like if we drilled down to open up the block to them,the oil would go right into the coolant passage - so we didn't. The rear oil drainback holes are fine. However, I am concerned that without the front holes working I'm getting too much oil pooling on top of the heads and it may effect the motor's ability to circulate the oil effectively at higher RPM.
Has anyone else ran into this issue?
Old 11-24-2012, 03:16 PM
lt1needingboost's Avatar
Default oil holes in heads????
gonna need to see pics of this to know what ur talking abt.I have never ever heard of this though.
Old 11-24-2012, 09:42 PM
TwoFast4Lv's Avatar
You must have one of the old sets. All the old sets were just converted SBC heads
We always cut the block for oil return there is lots of meat to do it
Yes we waitied 4 monthes for this set!
Old 11-25-2012, 09:54 PM
TWS
TWS's Avatar
Thanks Ellis. I'm going to give you a call this week.
Old 11-25-2012, 09:56 PM
TwoFast4Lv's Avatar
Any time man!
Old 11-27-2012, 07:33 AM
quik95lt1's Avatar
my trick flows did that as well i did what ellis did......just round off the edge of the block there and give the oil a ramp straight into the lifter valley......piece of cake a die grinder and a few min......make sure you do it before you have the block washed it makes a mess!!!
Old 11-30-2012, 03:35 PM
WS Sick's Avatar
Yes my older 190 s had this trouble as well, I enlarged the head hole slightly and blended the block to match.
Quick Reply: AFR 210 LT4 heads... front oil drain back holes??
