Starting a build
Old 12-11-2012, 08:25 PM
94gt8er's Avatar
Default Starting a build
I've decided to start building my car and wanted some input
LE2 heads
LE custom grind cam 232/240
Ported lt1 intake
3600 yank stall
3:73
Pacesetter long tubes
Ory
Magnaflow cat back
Please leave input on what you think or if I should add something.
Old 12-11-2012, 10:05 PM
rich5368's Avatar
Pretty similar to my setup with a little bit higher duration cam. It's solid looking to me. I'd start saving for a beefier rear end though. All that torque has to go somewhere and that usually means a shattered 10 bolt. Cat back is cool, personally if you go cat back I'd get a cutout. Every .01 of a second counts right?
Old 12-12-2012, 03:44 AM
TravisMcGill2000's Avatar
Looks like a great setup. Just remember to buget in the small things. Like 255 fuel pump, bigger injectors, 1.6rr, timing chain, gaskets, tune and so on
Old 12-12-2012, 06:15 AM
RamAir95TA's Avatar
What are your goals?
Quick Reply: Starting a build
