24X 1336 SES Code - Crank Relearn
Old 04-19-2013, 04:34 PM
roadtrip120's Avatar
Default 24X 1336 SES Code - Crank Relearn
I helping a friend finish up his 24X conversion and the tuner needs to do a Crank Relearn on the PCM to get the crank to match up to the injectors.
HP Tuners will not say "Ready to Relearn"... On LS1 cars is requires a specific coolant temp, the hand brake to be set, and above a certain rpm.. I'm pretty sure he did not tie the emergency brake into the ls1 pcm wiring. The car starts and runs, the coolant temp works, but no E-Brake signal.
Does anyone know how to get a 24X LT1 to perform a Crank Relearn, with HP Tuners?
Old 04-19-2013, 11:35 PM
SoxXpupPeT's Avatar
I am not sure with HPTuners. When i had to do mine i brought it to my mechanic and plugged his scanner into it. It detected the code and asked if i wanted to do the relearn. Hit yes and floored it until the fuel cut off. After that it was done.
Old 04-20-2013, 09:13 AM
97lt1camaro's Avatar
Are you scanning while trying to do this? I'm pretty sure you have to be " connected" but not scanning. I'm fairly sure I ran into this problem as well with my 24x swap
Quick Reply: 24X 1336 SES Code - Crank Relearn
