throwing white smoke. head gaskets?
Old 06-27-2013, 10:02 PM
johnamenz28's Avatar
Default throwing white smoke. head gaskets?
went to clean the Camaro today and as im in the stall I notice a cloud of white smoke. low coolant light came on and it smells sweet. is that the tell tale sign of a bad head gasket? I haven't noticed any other drivability issues. idles fine holds decent oil pressure and hasn't over heated at all. thanks again- John
Old 06-27-2013, 10:44 PM
shbox's Avatar
Pretty much. You might want to pressure test the cooling system and/or check the plugs for signs. A plug in a cylinder with a leak will be very clean.
Old 06-28-2013, 08:46 AM
jaycenk's Avatar
^^ This, Mine did the same thing. White smoke was the only sign along with low coolant in the rad. At start up it would poor white smoke and then stop once the temp came up and then it mostly resealed. When I took it apart the cylinders with the leaks (both rear cylinders) were steam cleaned. Looked like brand new parts.
Old 06-28-2013, 09:08 AM
quik95lt1's Avatar
been there done it.....white puffs = bad head gasket
Old 06-28-2013, 11:52 AM
Village Troll
SS RRR's Avatar
Most likely a head gasket. As said, pressure test to confirm. Take plugs out before doing test.
Quick Reply: throwing white smoke. head gaskets?
