non-vented opti to vented opti
Old 07-01-2013, 09:17 AM
1hotlt1's Avatar
Default non-vented opti to vented opti
I been reading of this conversion for the past 2 days, the only part I don't get is about the little pocket (hole) of the cam. I have a roller comp cam and if the hole is the smaller one I won't be able to do the conversion right?
Thanks guys.
Old 07-01-2013, 09:37 AM
RamAir95TA's Avatar
You could just pick up an MSD cap and rotor. It turns a nonvented opti into a vented one. Magic!
Old 07-01-2013, 10:03 AM
1hotlt1's Avatar
Yea but the reasond am traying to do this swap is to instsll a stranger timing chaing, since the motor i pick up is 355 and going to shot a 200 shot and dont want to keep my stock chain.
Old 07-01-2013, 10:11 AM
quik95lt1's Avatar
what does a timing chain have to do with spraying a 200 shot?
Old 07-01-2013, 10:15 AM
shbox's Avatar
LS1Tech 10 Year
Most (or all) aftermarket cams for the LT1 have the large hole, so they will fit every year. If you have the cam number, call Comp with it and verify.
Old 07-01-2013, 10:33 AM
1hotlt1's Avatar
Stronger chain, since the nonvented set up you dont really have options on stronger chains.
Old 07-01-2013, 10:34 AM
1hotlt1's Avatar
will do thank you.
Quick Reply: non-vented opti to vented opti
