Lt1 Solid Roller 1.580 springs (guys running these come in)
Im going solid roller and have some Manley Nextek 1.580 springs and didnt even think about until now how the center head bolt is gonna work? I mean guys running these, can you get the 12 point nut off (with studs) with a spring this big? Or bolts? Just curious if I have to take the 2 center springs off to torque the head or not.
9-Second Club
I answered this one, right? You could use an Allen bolt in the center position with those big-assed springs. A 12 point is too big to install or remove with a 12 point bolt, without removing the center springs. The pn 1350, 1.5" dia PAC springs I told you about are 350 on the seat, well over 900 lbs open. They last just as long as those Manleys, and you won't have to pull the center springs to get the heads on & off. Normal SBC heads don't have this issue due to the different valve centerlnes.
I had to try a few different sockets, but finally found one thin enough to fit between the springs. Make sure the washer under the nut doesn't interfere with the springs too. I had to trim the washer a bit with a grinder on each side.
With 1.55" valvesprings I used ARP head studs with the smaller 12pt head, then ground the walls down on a socket to fit between them. Also had to trim the sides of the middle washers as well.
Tight fit.
Tight fit.
Village Troll
Dunno why an allen bolt is necessary? I had little difficulty removing/retorquing. As far as it being too big? I was told by a machine shop and a friend of mine who ran the same cam I am, which is considered a small SR by today's standards, that it required approx 250 on the seat and 500 on the nose. Right now mine is set up with 240 on the seat. Within about 5 to 7K miles worth of driving the springs have consistently lost about 5lbs.
My 1.55 PAC springs are 260 closed 740 open, and I have some of comps most aggressive non-drag SR lobes. Don't see too many LT1s running pure drag lobes that need a triple spring with 900+#s open, so I think a better spring choice could have been made then 1.58" Nextek's.
Manley makes a great spring, I just don't think it is probably needed in this case - but the OP never told us specifics so who knows, maybe it is a nasty 270+ duration .800" solid roller that needs a giant BBC spring.
9-Second Club
If an 8500 + RPM, .850" lift 290@ .050" cam doesn't need big diameter springs, why would any of you? Mine uses 350/360 lbs on the seat, 1015 open. I ran 1.625" Manley springs, I get just as many runs out of these 1.5" PAC springs with plenty of room on the 12 point center head bolts. They also make milder springs that size.
Village Troll
Meh, whatever. Perhaps the builder chose this spring for longevity sake since it sees more street duty than anything else? I don't know. These decisions were made back in 2005 or '06 IIRC so not sure if that may have been before the "breakthroughs" of lighter duty springs for aggressive lobes...
9-Second Club
I don't know about lighter duty. LOL
As I said, these smaller diameter springs last as long as the bigger ones. No rocker arm clearance problems either. None of the race engine builders I deal with have found a down side.
Village Troll
What I mean by "lighter duty" is all the chatter that has been going on the last few years using significantly smaller springs for cams that normally use a heavier spring. Regardless, I'll take what you said into consideration if/when I need a new set of springs.
